TwinTurbo.NET: Nissan 300ZX forum - Re: Knock Sensor question?
blackice98
on July 08, 2013 at 11:58 PM
posted by zx1988
on July 07, 2013 at 10:52 PM
Did you check your codes? I had a code for det. sensor that I discovered after I spun a bearing. Just fix it if its broken. It'll save you later.
zx1988
22:52:03 07/07/13
Will not affect idle. It can cut boost in ECU=safe mode. (n/m)
OverZealous (CT)
23:20:47 07/07/13
It shouldn't cause a rough idle.
baggar11
12:36:52 07/08/13
Re: Knock Sensor question? -
blackice98
23:58:00 07/08/13
marker_l13
19:22:11 07/10/13
